Is this a database or CSV import?
If an SQL database, these might be useful.
Byte Array Image from Database to JMP
downloading large columns from database via odbc
If this is CSV data, how are you opening it? Sharing the open() statement or dialog might help. Also the Source script from the bad import. JMP should be able to read very large strings; how did you determine the length of the imported string?
Here's a quick test using open(...csv)
x = "1," || Encode64 Blob( Char To Blob( Repeat( "the quick brown fox", 30000 ) ) ) || ",3"; Show( Length( x ) );
y = "4," || Encode64 Blob( Char To Blob( Repeat( "jumps over the lazy", 30000 ) ) ) || ",6"; Show( Length( y ) );
file = Save Text File( "$temp/x.csv", "a,b,c\!n" || x || "\!n" || y );
dt = Open( file );
Show(
JMP Version(),
Length( dt:b[1] ),
Length( dt:b[2] ),
Blob Peek( Decode64 Blob( dt:b[1] ), 0, 38 ),
Blob Peek( Decode64 Blob( dt:b[2] ), 0, 38 )
Length(x) = 760004;
Length(y) = 760004;
JMP Version() = "17.2.0";
Length(dt::b[1]) = 760000;
Length(dt::b[2]) = 760000;
Blob Peek(Decode64 Blob(dt::b[1]), 0, 38) = Char To Blob( "the quick brown foxthe quick brown fox", "ascii~hex" );
Blob Peek(Decode64 Blob(dt::b[2]), 0, 38) = Char To Blob( "jumps over the lazyjumps over the lazy", "ascii~hex" );
(a lot of) base 64 data in middle column
the Source script looks like this
Open(
"$TEMP/x.csv",
columns(
New Column( "a", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "b", Character, "Nominal" ),
New Column( "c", Numeric, "Continuous", Format( "Best", 12 ) )
Import Settings(
End Of Line( CRLF, CR, LF ),
End Of Field( Comma, CSV( 1 ) ),
Strip Quotes( 0 ),
Use Apostrophe as Quotation Mark( 0 ),
Use Regional Settings( 0 ),
Scan Whole File( 1 ),
Treat empty columns as numeric( 0 ),
CompressNumericColumns( 0 ),
CompressCharacterColumns( 0 ),
CompressAllowListCheck( 0 ),
Labels( 1 ),
Column Names Start( 1 ),
First Named Column( 1 ),
Data Starts( 2 ),
Lines To Read( "All" ),
Year Rule( "20xx" )
