HansD
Query Builder filtering on date stored in Varchar(20)
Query Builder - date filter.
SQL Server
JMP version 16.2
In the database (SQL Server) I get the Date field called RETURNDATE in ‘varchar20’ – I would like to use the Calendar functionality in the filter to select my dates
I tried to create a calculated column (Calc1) and specify CAST([RETURNDATE] as date), which he doesn’t like.
Using SQL outside Query Builder
SELECT TOP (1000) [LABJOBNO]
      ,[DESPATCHNO]
      ,CAST([RETURNDATE] as date) as CRETURNDATE
No problem
Using
Open Database( in JMP JSL with
WHERE ( CONVERT(DATE, DESPATCHRETURN.RETURNDATE, 106) between '01/01/2019' AND '12/31/2019')
Also no problem
Query builder doesn’t allow the entering of the quoted date string in the filter
Any advice?
Hans
0 REPLIES 0
