Shahars
update table based on timestamp
I have two tables. (A and B)
Table A contain (2000events along the duration of a test) events marking the beginning of a period and the name of the period at specific timestamps (underlined line is header)
TimeStamp, Period
30-12-2021 17:35:49.1, A
30-12-2021 17:39:36.8, B
so Period A is between "30-12-2021 17:35:49.1" and "30-12-2021 17:39:36.8"
Table B is of a log file recording data also with timestamps (underlined line is header) around 6000000 datapoints
timestamp, sensor1, sensor2, sensor3,...
30-12-2021 17:37:21.2, value, value, value,...
30-12-2021 17:37:22.2, value, value, value,...
30-12-2021 17:37:23.2, value, value, value,...
I would like to add a now column to table B with the Period value from Table A  based on the value of the timestamp in B.
If timestamp in B is bigger or equal than timestamp in Row (N) in table A AND also smaller than timestamp in Row (N+1) of table A then the period value in Row (N) will be assigned for that record in table B (timestamp in B is between two timestamps in A)
Any suggestions?
Thanks
ErraticAttack
Re: update table based on timestamp
Sort the lookup table and use Loc Sorted(). Check the function in the Scripting Index to see how it works.
Jordan
Here is a possible solution using @ErraticAttack  suggestion on the method to use.
dta = Data Table( "table A" );
dtb = Data Table( "table B" );
// Place all timestamp values from Table A & B
timesa = dta:timestamp << get values;
timesb = dtb:timestamp << get values;
// Find the row to add the data to
rows = Loc Sorted( timesa, timesb );
// Add the new columns to Table A
dta << New Column( "sensor1" );
dta << New Column( "sensor2" );
dta << New Column( "sensor3" );
// Loop through matrix rows and add the records to the appropriate
// row in Table A
For( i = 1, i <= N Rows( rows ), i++,
	theRow = rows[i];
	dta:sensor1[theRow] = dtb:sensor1[i];
	dta:sensor2[theRow] = dtb:sensor2[i];
	dta:sensor3[theRow] = dtb:sensor3[i];
Shahars
Thank you very much ErraticAttach and txnelson
Jim, could it be that the indexing is backwards somehow?
the Loc sorted is getting for each row in B the row number in Table A that contain the information I want to put in table B
However, i get an error inside the Loop about the scoping.
1. if I understand correctly, "rows" should have the same number of rows as table B
2. the parameter "i" increase from 1 to the number of rows in B.
3. in each iteration of the loop , the parameter "theRow" is assigned the corresponding i'th number in "rows".
so it actually holds the a number representing a specific line in table A that holds the data I want.
4. so now all we need to do is read the value in the appropriate column in A on that line and put it in the i'th row of B in the column I want.
However, I get an error about "scoped data table access requires a data table column or variable in access or evaluation of ..."
looking at the code I think that the script is referencing the wrong number as the index.
so I Switched between [i] and [theRow]
	theRow = rows[i];
should actually read
	theRow = rows[i];
	dta:sensor1[i] = dtb:sensor1[theRow];
	dta:sensor2[i] = dtb:sensor2[theRow];
	dta:sensor3[i] = dtb:sensor3[theRow];
however that does not help either.
I am still not familiar with JSL, so could it be that the way I specify the values or the column and row be incorrect?
Thank you, very much.
Shahars
solved this by changing the loop to be
	theRow = rows[i];
	//show(theRow);
	//show(subscript(dta,theRow,15));
	subscript(dtb,i,8) = subscript(dta,theRow,17);
	subscript(dtb,i,9) = subscript(dta,theRow,15);
	subscript(dtb,i,10) = subscript(dta,theRow,16);
however if there is a quicker way to run it I would be happy to learn. Thanks.
