I've been using Query Builder and File->Connect To->ODBC->Open Database Table to get data from a PostgreSQL data base.
The table I am getting from the database contains a column with large text strings.
My text strings are getting clipped when they exceed a length of 524,587. (2^19 -1)
Is there a setting in JMP and/or JSL that I can change to enable querying larger string values?
Motivating Situation and Debug Findings
I have been exploring the capabilities of the Torch Deep Learning add-in.
I have downloaded a kaggle data set of Dogs vs Wolves.
I used the Import Multiple Files JMP feature to create a data table that contains all of these files (2000 files).
I used JMP to clean up the data, create a response column, and validation columns, etc...
I created a PostgreSQL database, schema, and table.
I used JMP to connect to the database table, concatenated my Dogs vs Wolves data, and saved the information back to the database. The picture column is saved as text in the database using new image( char to blob("...the image info...") )
I have reviewed the data in the database, and everything appears as expected.
I used Query Builder to connect to my database and query the entire Dogs vs Wolves table.
I converted the Picture column from data type Character to Expression to get the images to show in the data table. Of the 2,000 entries, 1986 of them work as expected. 14 of the pictures don't display correctly. These entries include the following pictures:
- wolves/wolf-names-e1528831052890.jpg
- wolves/wolf-cubs.jpg
- wolves/wolf-4191896__480.png
- wolves/pexels-photo-682375.jpeg
- wolves/pexels-photo-682361.jpeg
- wolves/nature-animal-wolf-wilderness.jpg
- wolves/michael-mazzone-xvLRLLfP22o-unsplash.jpg
- wolves/hero_gray_wolf_animals.jpg
- wolves/gray-wolf_thumbJPG.jpg
- wolves/gray-wolf.jpg
- wolves/Winter-wolf-snow_-_West_Virginia_-_ForestWander.jpg
- wolves/SRX_WOLF_TRAPPING1.JPG.jpg
- wolves/Eurasian_wolfJPG.jpg
- dogs/n02106382_3756.jpg
I have reviewed the Picture information and found that the rows with issues don't have all of their information. The entries end in the middle of the image information.
I have reviewed the length of the Picture information and found that the corrupted Pictures all have a character length count of exactly 524,287. (2^19 - 1).
I have attempted to change the JSL parameters created by Query Builder, but I have not been successful in resolving the text length clipping. I'm not an SQL expert so I'm hoping that changing some of these settings can resolve my issue.
New SQL Query(
Connection(
ODBC:AB=0;
BATCHSIZE=100;
BI=0;
BOOLSASCHAR=0;
BYTEAASLONGVARBINARY=1;
COMMLOG=2;
CONNSETTINGS=;
D6=-101;
DEBUG=2;
DRIVER={PostgreSQL Unicode(x64)};
EXTRASYSTABLEPREFIXES=;
FAKEOIDINDEX=0;
FETCH=100;
FETCHREFCURSORS=0;
IGNORETIMEOUT=0;
KEEPALIVEINTERVAL=-1;
KEEPALIVETIME=-1;
LFCONVERSION=1;
LOWERCASEIDENTIFIER=0;
MAXLONGVARCHARSIZE=8092;
MAXVARCHARSIZE=255;
OPTIONALERRORS=0;
PARSE=0;
PQOPT=;
PROTOCOL=7.4;
READONLY=0;
ROWVERSIONING=0;
SHOWOIDCOLUMN=0;
SHOWSYSTEMTABLES=0;
SSLMODE=disable;
TEXTASLONGVARCHAR=0;
TRUEISMINUS1=0;
UNIQUEINDEX=1;
UNKNOWNSASLONGVARCHAR=0;
UNKNOWNSIZES=0;
UPDATABLECURSORS=1;
USEDECLAREFETCH=1;
USESERVERSIDEPREPARE=1;
XAOPT=1;
QueryName( "dogs_v_wolves" ),
Select(
Distinct,
Column( "Picture", "t1" ),
Column( "Label", "t1" ),
Column( "File Path", "t1" ),
Column( "Short File Name", "t1" ),
Column( "FoldA", "t1" ),
Column( "FoldB", "t1" ),
Column( "FoldC", "t1" ),
Column( "Validation", "t1" )
From( Table( "dogs_v_wolves", Schema( "dogs_v_wolves" ), Alias( "t1" ) ) )
) << Run;
I have attempted to change the JSL parameters created by Open Database Table, but I have not been successful in resolving the text length clipping. Again, I'm not an SQL expert so I'm hoping that changing some of these settings can resolve my issue.
Open Database(
AB=0;
BATCHSIZE=100;
BI=0;
BOOLSASCHAR=0;
COMMLOG=2;
CONNSETTINGS=;
D6=-101;
DEBUG=2;
FAKEOIDINDEX=0;
FETCH=100;
FETCHREFCURSORS=0;
IGNORETIMEOUT=0;
KEEPALIVETIME=-1;
LFCONVERSION=1;
MAXVARCHARSIZE=255;
OPTIONALERRORS=0;
PARSE=0;
PQOPT=;
PROTOCOL=7.4;
READONLY=0;
ROWVERSIONING=0;
SHOWOIDCOLUMN=0;
SHOWSYSTEMTABLES=0;
SSLMODE=disable;
TRUEISMINUS1=0;
UNIQUEINDEX=1;
UNKNOWNSIZES=0;
UPDATABLECURSORS=1;
USEDECLAREFETCH=1;
XAOPT=1;
"SELECT * FROM dogs_v_wolves.dogs_v_wolves"
To further investigate the situation, I created a python script that performs an SQL query and saves the results into a pandas dataframe. Then I created a JSL file that runs the python script file and converts the pandas dataframe into a JMP data table.
The python file is named "sqlQuery.py" and contains:
import pandas as pd
import sqlalchemy as db
engine = db.create_engine("postgresql+psycopg2://##connection information##")
query = """
SELECT DISTINCT *
FROM dogs_v_wolves.dogs_v_wolves;
df = pd.read_sql_query(query, engine)
The JSL file contains:
pythonFilePath = "sqlQuery.py";
Python Submit File( pythonFilePath );
dt = python get(df);
dt:Picture << set data type(expression);
When I run this code the data table contains the full text strings. When I convert the Picture column to an Expression data type, the images are displayed correctly.
Conclusions
JMP is successfully writing large text strings to the database.
JMP is clipping large text strings when querying from the database using Query Builder and/or Open Database Table.
Running an SQL query outside of JMP returns the full-length text strings that are stored in the database.
Desire
I would like to be able to utilize the convenience of Query Builder while working on my image processing projects.
Question
