FN
FN
Python Send() does not recognize datetime format (sent as string)
When sending datatables to pandas dataframes (Python), numeric values (datetimes) are sent as strings.
I would not expect this behavior, since now I have to deal with this manually (considering datetimes in Python and JMP are different).
Any workaround? I imagine the easiest would be to transform the JMP format to integer, send this information, and transform the date considering the logic behind JMP dates (sum of seconds since specific date).
ClearLog();
dt = Open( "$SAMPLE_DATA/Functional Data/Weekly Weather Data.jmp");
t = dt << Subset(
			Allrows,
			Columns(:DATE)
Python Init();
Python Send( t );
Python Submit( "
import pandas as pd
print(t.dtypes)
Python Term();
// Output
// DATE    object
// dtype: object
// Types: https://pandas.pydata.org/pandas-docs/stable/reference/api/pandas.DataFrame.dtypes.html
//float              float64
//int                  int64
//datetime    datetime64[ns]  << Expected
//string              object
//dtype: object
FN
FN
Re: Python Send() does not recognize datetime format (sent as string)
PythonSend() saves temporary csv which are read with the default pd.read_csv('myfile.csv'), hence no parse_date.
To deal with this, one option which is not impacted by the date format:
ClearLog();
t = dt << Subset(
			Allrows,
			Columns(:DATE)
t:DATE << Format(best);
Python Init();
Python Send( t ); // send the opened data table represented by dt to Python
Python Submit( "
import pandas as pd
print(t.dtypes)
print(t.head())
t.iloc[:,0] = pd.to_datetime(t.iloc[:,0], unit='s', origin=pd.Timestamp('1904-01-01'))
print(t.dtypes)
print(t.head())
Python Term();
// Output
// DATE    int64
// dtype: object
//         DATE
// 0  3534451200
// 1  3535228800
// 2  3537648000
// 3  3538252800
// 4  3538857600
// DATE    datetime64[ns]
// dtype: object
//        DATE
//0 2016-01-01
//1 2016-01-10
//2 2016-02-07
//3 2016-02-14
//4 2016-02-21
If there is a better way, let me know.
ih
Super User (Alumni) ih
This message string was for R, but I think you can use the same concept for Python.
https://community.jmp.com/t5/Discussions/How-to-send-dates-as-characters-from-JMP-to-R/td-p/50112
FN
FN
ClearLog();
t = dt << Subset(
			Allrows,
			Columns(:DATE)
Python Init();
Python Submit( "
import pandas as pd
print(t.dtypes)
print(t.head())
print(t.dtypes)
print(t.head())
Python Term();
// Output
// DATE    int64
// dtype: object
//         DATE
// 0  3534451200
// 1  3535228800
// 2  3537648000
// 3  3538252800
// 4  3538857600
// dtype: object
//        DATE
//0 2016-01-01
//1 2016-01-10
//2 2016-02-07
//3 2016-02-14
//4 2016-02-21
