GregMcMahon
Putting labels in custom maps
I've built a custom map and it looks beautiful in Graphbuilder. What I would like to do is add labels to the regions in it but I just can't seem to figure out how that is done. An example would be from the online tutorial where the study is of temperature distributions in an office building. They describe how to make the custom map and the final result shows the actual room numbers on the map itself, but unfortunately it wasn't described how they got there. Or a simpler example would be putting the state names within the US map.
Thanks very much!
Best regards,
Gre
Re: Putting labels in custom maps
Set Label to column you want to show and then select all rows you want to have the label on and set labels on those:
and then create your map
