qt
qt
How to use column name as a variable.
I want to select some rows from a column ( I have a column named as 'RESOLUTION' in the current data table)
This two lines will work:
dt = Current Data Table();
dt<<Select Where(RESOLUTION > 0.);
If I define 'RESOLUTION' as another variable, it doesn't work:
colA="RESOLUTION";
dt<<Select Where(column(dt, colA) > 0.);
This will not select any row.
Could someone kindly tell me how could I do this?
Thanks.
pmroz
Re: How to use column name as a variable.
qt,
This will do the trick.
colA = "Resolution";
col_expr = "dt << Select Where(:name(\!"" || colA || "\!") > 0.)";
eval(parse(col_expr));
Basically you're creating some dynamic code, and then executing it.
qt
qt
It works!!
Many thanks!
David_Burnham
Alternatively use the AsColumn function:
colA="RESOLUTION";
dt<<Select Where(AsColumn(colA) > 0.)
-Dave
tsl
tsl
One thing to watch with using As Column() is that it seems to be much slower than using the eval( parse(..)) syntax for a large data table.
In my case I had a data table with 390k rows and 17 columns.
Using Eval ( Parse ( .... )) took 67 msec to select the rows I was looking for while using the As Column() syntax took 3,600 msec !  ( using HPTime() to measure )
So while the As Column() syntax is a whole lot more readable in the code, if speed matters, it may not be the best option
It might make AsColumn() faster if you combine it with Column().
Re: Should you Loop through a data table or use Recode, or use Get Rows Where to change values in a ...
