AdditiveRange10
Process Capability Module with grouped spec limits
I am currently on JMP16 but looking to upgrade to 18 soon.
I have read some of the discussions on the topic. Basically, if we have a dataset with multiple parts that each have their own spec limits (for the same metrics) the way to evaluate them all at the same time is using the process screening platform and an associated spec limit table. If we were to try this in the Process Capability platform even with a spec limit table we would only be able to apply one set of target, LSL and USL per each metric column. This seem an oversight since the Process Capability platform has more options for graphical representation and analysis compared to the Process Screening one.
Has this been resolved in JMP 18?
Is there any other way to go around this using scripting? I have read that otherwise one must do table splits and perform each process capability analysis per part/sample but when you have tens or hundreds of them it becomes not feasible.
Any help would be appreciated.
shampton82
Re: Process Capability Module with grouped spec limits
* Response removed
shampton82
* Response removed
