lodey101
Problems with Graph update function
Hi there - I have a script that works to a certain point - It gets a list of specfic columns, assigns these to a list and then uses a combobox to let the user select which column to use for a graph creation. This works fine but the problem is now that when the graph is created it will display outside the window and also appends the new graph - i just need to update the window with the new version.
See the sample script below
// Create the dialog window win = New Window("Count Analysis by EXPSORTWW_XETA", V List Box( header_text, Text Box( " " ) ), VListBox( PanelBox("Controls", HListBox( TextBox("X-axis: EXP_XETA", <<Set Font Style("Bold")), Spacer Box(size(20, 1)), TextBox("Overlay Variable:"), overlayCombo = ComboBox(magicalArray, <<Set Width(200)) ) ), PanelBox("Graph", gb_test = V List Box() // Container for the graph ) ) ); // Set change handler overlayCombo << Set Function( Function({this}, overlayVar = this << Get Selected; Show( "Selected: " || overlayVar ); // Debug updateGraph( overlayVar ); ) ); updateGraph = Function({overlayVar}, // Create new graph if variable is selected write(overlayVar); gb = expr(Graph Builder( Size( 550, 450 ), Show Control Panel( 0 ), Variables( X( :EXPSORTWW_XETA ), // Explicit column reference Overlay( Column( pc_inline, overlayVar ) ) ), Elements( Bar( X, Legend(5), Summary Statistic("N"), Bar Style("Stack") ) ) )); // Add the graph to the window gb_test << Prepend( V List Box( gb )); // Optional formatting Report( gb )[FrameBox(1)] << Background Color("Light Gray") << Transparency(0.2); ); // Initialize with first variable If( N Items( magicalArray ) > 0, overlayCombo << Select( 1 ); updateGraph( magicalArray[1] ); // Force initial graph );
Could anyone help me out and see what is wrong?
Re: Problems with Graph update function
This maybe gives some ideas what you could change (remove old graph, don't mix expression and reference)
options = {"height", "weight"};
	V List Box("", Text Box(" ")),
	V List Box(
		Panel Box("Controls",
			H List Box(
				Text Box("X-axis: EXP_XETA", <<Set Font Style("Bold")),
				Text Box("Overlay Variable:"),
				overlayCombo = Combo Box(options, <<Set Width(200))
		Panel Box("Graph",
	Function({this},
		updateGraph(overlayVar);
	gb_expr = Expr(
		gb = Graph Builder(
			Size(550, 450),
			Show Control Panel(0),
			Variables(
				X(:age),
				Overlay(Eval(overlayVar))
			Elements(Bar(X, Legend(5), Summary Statistic("N"), Bar Style("Stack")))
	Try((gb_test << child) << Delete Box);
	gb_test << Prepend(V List Box(gb_expr));
	Report(gb)[FrameBox(1)] << Background Color("Light Gray") << Transparency(0.2);
If(N Items(options) > 0,
	updateGraph(options[1]);
