STAT
Problem with Games-Howell test
Hi, I am trying to undertake the Games-Howell test with the Add-in, however always receive the error notificiation: "Argumentwert ist ungültig bei Zugriff oder Auswertung von group1 , group1/*###*/" (sorry, it is in German - it says something like argumentation value is invalid or the evaluation of Group 1, Group 1/*###*/). What does that mean? What is the problem? The add-in is generally functioning because when I try it out with another column it functions (the only difference is that there is somewhat more data in the column that works, but basically it is the same kind of type of data, i.e. just numbers). I would be very grateful if someone could help me.
Re: Problem with Games-Howell test
Did you contact the author of the add-in?
STAT
no, I didn´t, but I experimented a bit and now found that the problem was that I had some samples without results which is normally not a problem in jmp. So, I deleted those rows and it eventually worked out :)
STAT
no, I didn´t, but I experimented a bit and found out the problem. I had some samples without results and this seemed to create the problem (this is normally not a problem in JMP). So I deleted all rows without data and it eventually worked :)
