キャンセル
次の結果を表示
表示  限定  | 次の代わりに検索
もしかして:
言語を選択 翻訳バーを非表示
tox
tox
Probit Slope Determination
I have a toxicology dataset and I want to calculate the median lethal dose and probit slope.  I have been able to follow some other threads and calculate the median lethal dose using probit analysis.  The results of an example analysis I performed are shown below.  I am looking to estimate the probit slope as well as the median lethal dose - is the probit slope the "log(load)" value under parameter estimates (i.e. 3.62)?  Any help/advice would be greatly appreciated.  Thanks!
1 件の受理された解決策
受理された解決策
cwillden
Re: Probit Slope Determination
It looks like you applied a log transformation to Load in the dialog, but yes that is the slope.
To get the LD50, you can just play with the profiler value for Load until you get 0.5, or you can use inverse prediction from the red-arrow menu next to "Generalized Linear Model Fit."  Just put whatever confidence in there and specify 0.5 for your quantile.  The predicted load value will show up in the results and you can just ignore the confidence interval stuff.
-- Cameron Willden
元の投稿で解決策を見る
2件の返信2
cwillden
-- Cameron Willden
tox
tox
Great - thanks for the help!
おすすめの記事
