Jackie_
Preventing New Window from being maximized/resized?
I want to prevent the new window from being maximized/resized. I am aware of the "<<Modal" window, but is there an alternate way?
Found this threat but it runs a scheduler in the background which I don't prefer
https://community.jmp.com/t5/Discussions/How-to-stop-users-from-resizing-windows-in-JSL/td-p/15168
Re: Preventing New Window from being maximized/resized?
No idea how that could be done.
But if you wish to provide very annoying user experience you can use graphic scripts
nw = New Window("Example", <<size(200, 200),
	gb = Graph Box(
		Frame Size(1, 1)
	box = V Splitter Box(
		Size(640, 480),
		H Splitter Box(
			Spacer Box(
				<<Set Fill(1);
				<<Color(RGB Color(9, 112, 84));
			Spacer Box(
				<<Set Fill(1);
				<<Color(RGB Color(255, 222, 0));
		H Splitter Box(
			Spacer Box(
				<<Set Fill(1);
				<<Color(RGB Color(101, 153, 255));
			Spacer Box(
				<<Set Fill(1);
				<<Color(RGB Color(255, 153, 0));
(gb << Xpath("//AxisBox")) << visibility("Collapse");
Eval(EvalExpr(
	gb[FrameBox(1)] << Add Graphics Script(
		Expr(nw) << Zoom Window;
Look in the Scripting Index for Window Size
w = new window("test");
w << Set Window Size( 800, 1200 );
To my knowledge you cannot easily do this, but few questions:
  1. The most important question: why would you want to prevent user from resizing a window (doesn't really fit the feeling of JMP to not be able to resize a window).
    1. One window in JMP which prevents you from maximizing it and it is Legend window but you can still resize it so maybe there is a way to disable maximizing
    2. Other is Caption() but it is it's own thing
  2. If you wish to prevent resizing, why not use modal window?
  3. Is there a specific issue in using scheduler?
  4. That thread has the most probable answer: you might have to go outside the scripting language and do it from the operating system
Jackie_
@jthi
  1. One window in JMP which prevents you from maximizing it and it is Legend window but you can still resize it so maybe there is a way to disable maximizing - I have never came across this, can you share an example code?
  1. If you wish to prevent resizing, why not use a modal window? - Bcos Modal window prevents accessing other files/tables
  2. Is there a specific issue in using scheduler? The issue is it slows down the loop
	gb = Graph Box(
		Frame Size(1, 1)
		Size(640, 480),
		H Splitter Box(
			Spacer Box(
				<<Set Fill(1);
			Spacer Box(
				<<Set Fill(1);
		H Splitter Box(
			Spacer Box(
				<<Set Fill(1);
			Spacer Box(
				<<Set Fill(1);
Eval(EvalExpr(
Jackie_
This is a nice hack. Thanks Jarmo
