kca
kca
Preferred method to abort JSL script
How can I tell JSL to stop executing a script?  I would like to know both the programmatic way and the keyboard shortcut way if possible.  I don't want to close JMP.
Thanks for your help!
Update: Digging around the scripting guide I found that Stop() stops a running script, and ESC does the same thing in the editor.
XanGregg
A related function is Throw(), which can be useful if you only want to abort part of the script. Combine it with Try() to control recovery.
XanGregg
jorgeramosdealm
Re: Preferred method to abort JSL script
From the manual
Infinite Loops
For loops that always evaluate as true create an infinite loop, which never stops. To end the loop as the script runs, press ESC on Windows (or COMMAND-PERIOD on Macintosh).
How do you start it again?
