JMP Security Notice: CVE-2026-109618 and CVE-2026-109619
How can I tell JSL to stop executing a script? I would like to know both the programmatic way and the keyboard shortcut way if possible. I don't want to close JMP.
Thanks for your help!
Update: Digging around the scripting guide I found that Stop() stops a running script, and ESC does the same thing in the editor.
For loops that always evaluate as true create an infinite loop, which never stops. To end the loop as the script runs, press ESC on Windows (or COMMAND-PERIOD on Macintosh).
How do you start it again?
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '4066' && "ForumTopicPage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if(value == '4066') {
}else{
sub_L = newSub.innerHTML;
else{
} else {
try{
catch(e){
if (value == '4066') {
if(subTkbElement){
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
