Instantly extract effect sizes, F-ratios, and FDR-adjusted p-values from your models with the Calculate Effects Sizes extension, available now in the JMP Marketplace!
New to JMP? Join us Sept. 23-24 for the Early User Edition of Discovery Summit, tailor-made for new users. Register now for free!
Your voice matters! Tell us how you prefer to receive JMP updates, so we can tailor our communication to your needs. Take short survey.
While using predicting screening to identify the contribution of each individual parameter among the data each time i run the program on the data different portion and contribution is observed.
That is correct. Becasue the predictor screening uses boostrap forests to generate the contributions, each time you run the procdure you may see different resutls. The larger the number of predictors, the more variblity you will see in the results. I often run the procedure 5 times and take the top contributors from each round and compare or feed them forward to the next step of my analysis.
For more info on the platform here is the overview help page:
