Hi all,
I'm trying to fit a model to full factorial experiment (4 factors, curvature likely in all).
I have a tight data fit (RSq=0.81). However, the prediction profiler is not generating any graphs. We didn't add centerpoints across all factors in the first pass of the experiment. Two of the factors we have center points for. If I simplify the model for screening and treat the data as continuous, I'm getting a fit, but it's not accurate. I also added in the centerpoints we have as "discrete numeric" and then performed a fit model. This fit is better, but again, it's not perfectly aligned with the data. Is this JMP's way of telling me it's lacking all of the data to make accurate predictions? We will be running another pass with centerpoints, I'm more asking if this is JMP's way of telling me it's lacking data.
