Level XIII
Powerpoint: trigger paste clipboard
Does Jmp have a possibility to trigger "paste clipboard" in Powerpoint - after copying a graph to the clipboard.
jules
Re: Powerpoint: trigger paste clipboard
Hi @hogi,
My favorite way to do things like this (on my Mac) is to use RunProgram() to run some AppleScript. Here's my process there, which I hope will be helpful if you're adapting for Windows.
On the JMP side, we're going to use RunProgram() to execute a bash script we'll make:
Run Program( Executable( "~/Desktop/pastePowerpoint" ) );
To make the bash script, we open a plain text file and write the bash to AppleScript invocation, and then the AppleScript. Here's the full contents of that plain text file:
#!/bin/bash
osascript <<END
tell application "Microsoft PowerPoint"
  activate
  tell application "System Events"
    keystroke "v" using {command down}
  end tell
end tell
END
Once we save that (with no extension), we need to make it executable. In Terminal, we can run the following (still assuming this is on your desktop):
chmod 755 ~/Desktop/pastePowerpoint
And that's it! Hope this helps!
@jules
jules
Hi @hogi,
#!/bin/bash
osascript <<END
  activate
  end tell
end tell
END
@jules
Level XIII
Thanks @jules.
Concening Windows, ChatGPT suggested to use a PowerShell Script:
(assuming that the JSL script and ps1 code are saved in the same folder)
Try(Current Report()<< Copy Picture();
If( Host is( "Windows" ),
PowerShellScriptName= Convert File Path( "", windows ) ||"PastePicture.ps1";
runOptions = "-File \!""|| PowerShellScriptName||"\!"";
MyResult = Run Program(
	Executable( "PowerShell.exe" ),
	Options( {runOptions} ),
	ReadFunction( Function( {this}, Write( this << read ) ) )
pastePicture.ps1:
$ppt = New-Object -ComObject PowerPoint.Application
$ActivePPT = $ppt.ActiveWindow
if ($ActivePPT -eq $null) {
  return "no active ppt"
} else {
$slide=$activeppt.Presentation.Slides($ppt.ActiveWindow.Selection.SlideRange.SlideNumber)
$shape = $slide.Shapes.Paste()
return 0
Level XIII
I added the windows version (via PowerShell) to the GraphBuilder toolbar:
Graph Builder Toolbar
