DanAlexander
Possible to add automatic graph creation in JSL script?
I wrote a JSL to organize experimental data which updates 22 data tables (corresponding to products), each containing columns for different physicochemical parameters (e.g. pH, osmolality). Currently, I am manually creating graphs using the Graph Builder feature and 'saving script to data table', however I was wondering if it was possible to write this into the main JSL script that is generating my data tables?
Each graph displays a particular parameter on the y-axis, and time on the x-axis, so I want to write code that generates graphs in each data table for each parameter, rather than having to manually make the graphs and save the script.
15 REPLIES 15
nascif_jmp
Re: Possible to add automatic graph creation in JSL script?
I am so sorry, I didn't check. Save Window to Report was introduced in version 16.0.
DanAlexander
Ah I see. I am using JMP 15. So I cannot use the Save Window to Report function.
nascif_jmp
I can save it in JMP 15 as a report using the UI "Save As" but I was not able to figure out how to do it using JSL.
It is a good question for the dev team. Are you in the Discovery Conference? The "Meet the Developers" virtual booth is open right now and our JSL experts are there.
nascif_jmp
All right, please see attached for JMP 15 compatible version.
DanAlexander
Thank you! I was finally able to save the graphs using your revised script.
nascif_jmp
I am glad to hear it is working for you! If you want something more interactive, take a look at the new graphlets feature in JMP 15. I think it might be a good fit for your data. The implicit hierarchies would make for nice drill-downs.
