UserID16644
Plotting with lower and upper limits
Hi all,
I have a function that creates cdf plots with lower and upper limits. However, when applied, the lower/upper limits are not being shown because of the axis minimum and maximum. What/how is the proper computation in order for the lower and upper limit to be shown from the plots?
Here is my sample function:
cdfplot = Function( {ycol, sl, ul}, {plot},
					cdf = Oneway( Y( Column( ycol ) ), X( :Lot ), Means and Std Dev( 1 ), Box Plots( 1 ), Mean Diamonds( 1 ), Mean Error Bars( 1 ),
					Std Dev Lines( 1 ), Comparison Circles( 0 ), Connect Means( 1 ), X Axis Proportional( 0 ), Points Jittered( 1 ), Grand Mean( 0 ));
					rcdf = cdf << report;
					//Convert rcdf to list if not list
					If( Not( Is List( rcdf ) ),
							rcdf = Eval List({rcdf});
					//Apply customization to cdf
					For( s = 1, s <= Nitems(rcdf), s++,
						Try( cmin = rcdf[s][axis box( 1 )] << Get Min() );
						Try( cmax = rcdf[s][axis box( 1 )] << Get Max() );
						rcdf[s][FrameBox( 1 )] << {Frame Size( 380, 250 ), Marker Size( 3 ), Line Width Scale( 1.5 )};
						rcdf[s][Text Edit Box( 1 )] << Set Font Size( 10 ) << Set Font Style( "Bold" );
						rcdf[s][Text Edit Box( 2 )] << Set Font Size( 10 ) << Set Font Style( "Bold" );
						rcdf[s][axis box( 2 )] << Format( "Best", 12 ) << Tick Font( style( 1 ), size( 9 ) ) << Show major Grid( 1 ) << Show Minor Grid( 1 ) <<
						Show Minor Ticks( 1 ) << Minor Ticks( 4 );
						Try( rcdf[s][axis box( 1 )] << Max(cmax) << Min(cmin) << Inc() << Minor Ticks( 1 ) );
						rcdf[s][axis box( 1 )] << Format( "Best", 12 ) << Tick Font( style( 1 ), size( 9 ) ) << Show major Grid( 1 ) << Show Minor Grid( 1 ) <<
						rcdf[s][Scale box ( 3 )] << Add Ref Line( ul, "Solid", "Red", "USL", 2 ) << Add Ref Line( sl, "Solid", "Red", "LSL", 2 );
					plot = rcdf;
//Function application
colname = {"AVG_1", "AVG_2", "AVG_3"};
ul = {11.5, "20", "100"};
ll = {8, 0.1, 6 };
lb = Lineup Box( N Col(4) );
For( i = 1, i <= N Items( colname ), i++,
	lb << Append( H List Box( cdfplot( colname[i], ll[i], ul[i] ) ) )
I have this plot as the result:
But it should be like this:
Re: Plotting with lower and upper limits
Two items
  1. Your ul list has character values instead of numeric values
  2. You need to check to see if your cmax and cmin are outside of your ul and sl values and if so, then reset their values.
    		range = abs(cmax-cmin);
    		if(sl<cmin, cmin =sl-.1*range);
    		if(ul>cmax,cmax=ul+.1*range);
Two items
