- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Get Direct Link
Plotting conditionally
Hi JMP Community!
I have the following piece of code as part of an add-in I made:
Report7 = Platform(
dt,
gb7 = Graph Builder(
Size( 632, 571 ),
Fit to Window( "Maintain Aspect Ratio" ),
Variables( X( :Order No. ),
Y( :S0a value, Position( 1 ) ),
Y( :S1a value, Position( 1 ) ),
Y( :S1b value, Position( 1 ) ),
Y( :S1c value, Position( 1 ) ),
Y( :S2a value, Position( 1 ) ),
Y( :S3a value, Position( 1 ) ),
Y( :S4b value, Position( 1 ) ) ),
Elements(
Line( X, Y( 1 ), Y( 2 ), Y( 3 ), Y( 4 ), Y( 5 ),
Y( 6 ), Y( 7 ), Legend( 11 ) )
The issue is that I don't always have all the columns that I'm asking the add-in to plot on the y-axis (e.g. the data table might only have S0a - S1c rather than S0a - S4b). When this is the case, the resulting plot is just a histogram of the x-axis column (i.e. of "Order No.").
Is there a way of making the code plot whatever columns are available and automatically ignore the ones that aren't? I'm open to other ideas as well.
Thank you in advance!
Ahmed
- Mark as New
- Bookmark
- Subscribe
- Mute
- Get Direct Link
Re: Plotting conditionally
This might be on option, you would need to populate the variables cols with the actual list you want to include:
Names default to here(1);
dt = Open("$Sample_data/probe.jmp");
//Variables to hold the dynamic parts of the graph builder expresssion
Expr1 = "";
Expr2 = "";
// Pick columns to include
cols = ( dt << get column names() )[random shuffle(8::397)[1::5]];
//Populate expressions
for(c=1, c<= n items(cols), c++,
Expr1 = Expr1 || "Y( Column( \!"" || cols[c] || "\!" ), Position(1) ),";
Expr2 = Expr2 || "Y( " || char( c ) || " ),";
Eval( Parse( substitute(
//the graph builder script as a string with 'dummy variables' where the
//expressions created earlier will go
"gb = Graph Builder(
Size( 838, 391 ),
Variables(
X( :DELL_RPPBR ),
Expr1_
Elements( Line( X, Expr2_ Legend( 10 ) ) ),
Local Data Filter(
Add Filter(
columns( :DELL_RPPBR ),
Where( :DELL_RPPBR >= -1 & :DELL_RPPBR <= 0.483837991952896 )
//replace the 'dummy variables'
"Expr1_",
Expr1,
"Expr2_",
Expr2
- Mark as New
- Bookmark
- Subscribe
- Mute
- Get Direct Link
Expr1 = "";
Expr2 = "";
Size( 838, 391 ),
Variables(
X( :DELL_RPPBR ),
Expr1_
Local Data Filter(
Add Filter(
"Expr1_",
Expr1,
"Expr2_",
Expr2
- Mark as New
- Bookmark
- Subscribe
- Mute
- Get Direct Link
