ndowidar
Plotting Correlations using tall vs wide datasets
I have duplicate measurements that I'd like to plot against each other to check for outliers. My problem is that I have two instances of the same data. So I've labeled one set A & the other B for given metric. In JMP, I can't seem to plot A vs B because they're in the same column. Do I have to label each metric with an A or B to plot them against each other?
 As an example I attached a simplified dataset. I'd like to make a correlation plot between Set A vs B using a correlation of coverage between the the two.
 Thanks so much!
Re: Plotting Correlations using tall vs wide datasets
Split the data table
     Tables=>Split
Split on Set
Split Columns on Reads and Coverage
Grouping on ID
Then you can easily correlate on the 2 columns created for reads and coverage
Look at Response Screening to get your correlations in a data table format
     Analyze=>Screening=>Response Screening
     Tables=>Split
Split on Set
Grouping on ID
