hogi
Level XIII
Display Box: Level?
Is the a command to get the level/depth (?) of a Display Box, i.e. the number ot parents to get to the top parent?
Re: Display Box: Level?
Based on the scripting index the purpose of << Get Display Path isn't to provide you with a full path but rather "robust" expression (robust path).
XPath or recursive function might be be fairly easy to implement (no idea if this will always work, some platforms in JMP can be quite complicated and some elements might not be captured)
nw = New Window("test", // 6
	Panel Box("1", // 5
		Panel Box("2", // 4
			Panel Box("3", // 3
				H List Box( // 2
					Spacer Box(100),
					Text Box("4"),
					V List Box( // 1
						Text Box("5"),
						Spacer Box(Size(100, 100)),
						tb = Text Box("6") // 0
get_parents = function({elem, idx = 0},
	next_elem = elem << parent;
	If(Is Empty(next_elem),
		return(idx);
	idx++;
	show(next_elem << class name);
	get_parents(next_elem, idx);
show(get_parents(tb)); // has also the headbox
parent_count = N Items(nw << XPath("//TextBox[text() = '6']/ancestor::*"));
9 REPLIES 9
How about using Get Display Path()? Get Display Path () gets a relatively expression to navigate between parent box and object. Ifyou want to count the number of parents to get to the top parent, try following jsl.
biv = dt << Bivariate( Y( :weight ), X( :height ), Fit Line );
rpt = Report( biv );
rootParent = rpt << Top Parent();
path_to_parent = rpt[number col Box( 9 )] << Get Display Path( rootParent, Mode( "Subscript" ) );
count = N Items( Words( Char( Eval Expr( path_to_parent ) ), "," ) );
hogi
Level XIII
I had the same idea
But it seems that sometimes Get Display Path doesn't go step by step:
New window("test",Panel Box("1",Panel box("2",PanelBox("3",HList Box(Spacer Box(100),Text Box("4"),V List Box(Text Box("5"),Spacer Box(Size(100,100)),tb=Text Box("6")))))));
rootParent = tb << Top Parent();
path_to_parent = tb << Get Display Path( rootParent, Mode( "Subscript" ) );
	Panel Box("1", // 5
		Panel Box("2", // 4
			Panel Box("3", // 3
				H List Box( // 2
					Spacer Box(100),
					Text Box("4"),
					V List Box( // 1
						Text Box("5"),
		return(idx);
	idx++;
hogi
Level XIII
Thanks.
I just tried it with a slightly different tree and got a stack overflow.
Here the parent function doesn't climb up the tree?!
New Window( "test",
H List Box( Panel Box(
 "", H List Box( Text Box( "Hallo" ), tb = Filter Col Selector() ) ) ) );
get_parents = Function( {elem, idx = 0},
	If( Is Empty( next_elem ),
		Return( idx )
	idx++;
	Print( idx );
	Show( next_elem << class name );
	get_parents( next_elem, idx );
Show( get_parents( tb ) );
If I would have to guess it reaches filter col selector and starts from beginning for some reason (Filter Col Selector is one of the buggiest and most annoying display boxes to work with in JMP in my opinion). XPath might still work but the query can be more annoying to build.
hogi
Level XIII
Ok,
let's see ...
Case TS-00034009
Thanks for reporting the issue! I can confirm that Development has received it and already made some improvements to the behavior of these display box messages for the next major release of JMP.
hogi
Level XIII
Thanks for fixing it.
Thank you for your reply.
How about the following script? The script repeats the parent function until it reaches the top parent.
nw = New Window( "test",
	pb1 = Panel Box( "1",
		pb2 = Panel Box( "2",
			pb3 = Panel Box( "3",
				H List Box(
					Spacer Box( 100 ),
					tb4 = Text Box( "4" ),
					V List Box(
						tb5 = Text Box( "5" ),
						Spacer Box( Size( 100, 100 ) ),
						tb6 = Text Box( "6" )
//count parent display box from target to top display box
count parent = Function( {nw, target, top}, //window, target display box, top display box
	top_parent = top;
	end = 0;
	current = target;
	displaybox_list = {};
	For( i = 1, And( end == 0, i < 100 ), i++,
		parent = current << parent();
		If( Is Empty( parent ),
			end = 1,
			current = parent;
			Insert Into( displaybox_list, current );
			If( top_parent == current,
				end = 1
	Eval List( {i - 1, displaybox_list} );
{count, displaybox_list} = count parent( nw, tb6, pb1 );
show(count);
