Marcoz
How do I add mean and standard deviation bar in Bivariate fit
Hi, I have a question regarding bivariate fit curve in JMP 17.0. Is there a way I can get the mean and standard deviation bar appear on the graph instead of having all results at the same time point?
Attached is a example of the graph I am working.
Re: How do I add mean and standard deviation bar in Bivariate fit
You can either turn on Summary Statistics in Bivariate or use Graph Builder and add the Caption Box from the top ribbon and enable mean and stdev to get the values.
If you want to visualize stdev as error intervals, use Graph Builder and from the Points options set summary statistic to mean and error interval to standard deviation.
Marcoz
Thanks for the quick reply. So that means there is no way we can show standard deviation bar in bivariate fit curve?
Not in Bivariate, but if you make your X variable (time point) into an ordinal modeling type, which would turn the Bivariate into a Oneway analysis, then you can turn it on from the Oneway red triangle Means and Std Dev.
Marcoz
Roger that, thank you.
