R2OKeefe
PickFile() from within a Project does not use file filters
When I use PickFile() outside of a project, it works as noted in the scripting guide, scripting index, and other posts here in the forums. However, when I run the script within a project, the window that opens is a different one. It seems to be in order to allow you to pick a file that is saved to the project itself, but the filters do not work even though it shows the folder that I specified as default. I can get the normal window to come up if I click "Browse", and then with the normal window the filters work correctly like they do when running the script outside the project. For this script, there is never going to be a case where the file is already in the project, so is there a way I can force it to go directly to the "normal" pick file window? I am trying to make this script easy to use for many different people across many different groups at the company, so requiring them to know to click "Browse" each time just seems like an added point of confusion.
DataFilePath = PickFile(
"Select Data File",
"$Downloads",
{"Data Files|log;txt", "All Files|*"},
1,
0
Currently using JMP 16.2.0, in Windows 10.
0 REPLIES 0
