manphoolfageria
Permutation test with two factors (A, B)
Hi, I am trying to perform a permutation test. I have a numerical Y variable and a factor X variable. I attempted to follow this: https://www.jmp.com/support/help/14-2/conduct-a-permutation-test.shtml, and was unable to find the simulate option or bootstrap after right clicking the F ratio. I have attached my data JMP file along with the graph output.
Thank you!
Re: Permutation test with two factors (A, B)
To check if you have JMP Pro, you can just look at the header on any JMP window, and it will say either JMP or JMP Pro
Or you can go to
     Help==>About JMP
If you have JMP Pro for version 14, you will have the ability to do the Permutation test
Are you running JMP Pro? The example requires JMP Pro
manphoolfageria
How to check whether I have JMP pro or not. I have JMP 14. Thanks
manphoolfageria
Also, how to add in permutation option in JMP 14.
Or you can go to
     Help==>About JMP
