padhikari
Percentage for each row
I am trying to find the percentage of fail for each membrane lot base on the count of fail to pass for each number of rows for the specific membrane lot number.
Re: Percentage for each row
Create a new data table using
     Tables==>Split
Selecting ODStatus   as the Split variable and
Selecting N Rows as the Split Columns
You should also Select MembraneLot of Just ........ as the Group column
In the new data table you will now have a Fail and a Pass column, which you can then create a New column and using a formula of
     :Pass/(:Pass+:Fail)
to create your % value
     Tables==>Split
     :Pass/(:Pass+:Fail)
KarenC
Two other options:
1. Tabulate: drag lot to the rows zone, status to the column zone, N to the Freq, and Row % to the cells.
2. Analyze > Consumer Research > Categorical then Responses = OD Status, X,Grouping = Lot, and Freq = N.
padhikari
Thank you so much for your help. It worked great!
