cjackso21
Pasting Graphs from JMP 14.0.0 into Word or PPT
When copying a graph into Powerpoint, Word or an email, the graph is selected correctly but once pasted it cuts off a portion of the graph.  Have to use snipping tool to copy and paste.   Attached examples
Re: Pasting Graphs from JMP 14.0.0 into Word or PPT
There have been previous Discussions on this issue.  I believe the issue has to do with using multiple monitors.  The solution is to upgrade to JMP 16, or to remove the additional monitor(s). before cutting and pasting.  I advise you to search the past discussions for the specific information on the issue.
