Discovery Summit 2026: Early User Edition - September 23-24.Register. It's free.
Created:
Sep 22, 2021 12:03 PM
| Last Modified: Jun 11, 2023 4:17 AM(2163 views)
When copying a graph into Powerpoint, Word or an email, the graph is selected correctly but once pasted it cuts off a portion of the graph. Have to use snipping tool to copy and paste. Attached examples
There have been previous Discussions on this issue. I believe the issue has to do with using multiple monitors. The solution is to upgrade to JMP 16, or to remove the additional monitor(s). before cutting and pasting. I advise you to search the past discussions for the specific information on the issue.
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '420246' && "ForumTopicPage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if(value == '420246') {
}else{
sub_L = newSub.innerHTML;
else{
} else {
try{
catch(e){
if (value == '420246') {
if(subTkbElement){
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
