MathStatChem
Parallel assign when the output is a vector
I am running a simulation where the output of the simulation is a vector, i.e.
F_Simulation=Function({a,b},
/* do simulation, resuling in 3 values that are put into a 1x3 matrix named
outvec */
outvec;
I want to do the simulation over a grid of values for the inputs a and b.  It seems like i could get a significant speedup in execution of the simulation study by parallelizing, using Parallel Assign.  Could be done?  Any suggestions on how to do this?
Re: Parallel assign when the output is a vector
Maybe these give some ideas as they contain examples using Parallel Assign()
