Overlaying datapoints and function in Graph Builder
Hello everyone,
I am trying to overlay datapoints from a column and a function line in Graph Builder. However, whenever I place the variables on the same axis and overlay them, I end up with either:
  • both the datapoints and the function drawn as points, or
  • both drawn as lines.
What I want is simple:
  • the column data should appear as points, and
  • the function should appear as a line,
    overlaid in the same graph.
Below is a JSL script that generates a small sample table with two random columns and a function column. Here, Column 1 and Column 2 are random values, and the function column is a polynomial function of Column 1. When I use Graph Builder, JMP places them on separate graphs unless I overlay them, and once I overlay, Graph Builder forces all Y variables to share the same element type.
It appears that Graph Builder cannot mix points and lines when multiple Y variables share the same axis in an overlay.
Attached is the plot that I currently see, showing how Graph Builder places the function and datapoints on separate axes or forces them into the same element type when overlaid. Here I am using the version JMP 18.
Does anyone know whether there is a way to overlay a function line and datapoints on the same graph in Graph Builder while keeping different element types? Or is Graph Builder limited in this case?
New Table( "Function_plot",
	Add Rows( 10 ),
	New Script(
		"plot_function",
		Graph Builder(
			Variables( X( :Column 1 ), Y( :function ), Y( :Column 2 ) ),
			Elements( Position( 1, 1 ), Formula( X, Y, Legend( 13 ) ) ),
			Elements( Position( 1, 2 ), Points( X, Y, Legend( 7 ) ) ),
				Dispatch( {}, "400", LegendBox,
					{Legend Position( {13, [1], 7, [0]} )}
	New Column( "Column 1",
		Numeric,
		"Continuous",
		Format( "Best", 12 ),
		Set Values( [3, 1, 5, 9, 3, 12, 15, 19, 21, 17] ),
		Set Display Width( 53 )
	New Column( "Column 2",
		Numeric,
		"Continuous",
		Set Values( [22, 76, 34, 19, 9, 45, 78, 63, 19, 5] ),
	New Column( "function",
		Numeric,
		"Continuous",
		Formula( :Column 1 ^ 3 + 5 ),
		Set Selected,
		Set Display Width( 47 )
Graph Builder(
		Dispatch( {}, "400", LegendBox, {Legend Position( {13, [1], 7, [0]} )} )
Level XIII
Re: Overlaying datapoints and function in Graph Builder
Use the "variables" setting and deactivate "Column 2" for the Formula Plot - and "function" for the points.
Level XIII
The values in Column 2 and "Function" are very different.
If you have access to JMP 19, you can try parallel Y Axes:
and create a plot like this one:
Thanks for the suggestions. This works!
