terapin
Overlay Plot Scripts Running as Graph Builder in JMP 15
Folks,
I've written dozens of JSL scripts that display my data using the Overlay Plot platform. With JMP 15, all these scripts are now run using the Graph Builder platform. This is creating a whole host of issues since the complex commands I've used in my OPs don't match up with, nor are they converted to, the appropriate GB commands.  Is it possible to turn off this "feature" and allow my scripts to run as OPs?  I sure hope so so that I can continue running my Overlay Plot scripts until I get them converted over to Graph Builder.
vince_faller
Re: Overlay Plot Scripts Running as Graph Builder in JMP 15
According to the new features document, no.
Now that overlay plots are deprecated, scripting support has been removed for them. Use Graph Builder to create overlay plots
Vince Faller - Predictum
Go to Preferences->Platforms->Overlay Plot. Uncheck "Use Graph Builder".
In the future, overlay plot may be completely removed. If possible, run the old overlay plot scripts in graph builder, fix any discrepancies between the graph builder output and the old OP output, and then export new graph builder scripts.
vince_faller
terapin
Thanks for sharing the solution.  I'll begin the task of converting all my OPs over to GBs.
