Ordering points in a centered grid plot
I have a scatterplot with centered grid:
I'd like to order the colors within each block of points (so, in each block of dots, reading left to right and top to bottom, first come all the blues, then the reds, etc). How can I accomplish this, preferably in Graph Builder with no JSL?
statman
Re: Ordering points in a centered grid plot
If you would attach your data table it would be quite helpful.  One thought is to add a column to the data table that designates the order you want.  Then go to Rows>Color or Mark by Column and select the newly added column.  You can customize the colors or markers.
Never mind, I was doing it wrong! I've attached the working solution
statman
Here is a data table. It's a little different to the screenshot above, but same idea. You can run the script to generate this plot:
I tried Rows > Color or Mark by Column, but it just added a little colored dot to each row in the table; I couldn't figure out how to actually rearrange the points in Graph Builder (or script) such that all blue ones come first, then all green ones, etc. Any ideas?
