Analyst
Prediction profiler - multiple inputs
If I have multiple settings  I want to check in prediction profiler (e.g. I have 3 parameters and I want to check 5 values for each) is there any way to put them all in at once or do you have to do it one by one? I'm working in JMP 14.2.
Re: Prediction profiler - multiple inputs
Assuming I understand what you want to do, I can think of a few different ways to do this. Here is one that I think is probably the easiest:
Add the conditions you want at the end of your data table. Don't worry about the response. You can leave that blank. Make note of the row numbers that contain your new conditions. Now go back to your profiler and from the Profiler red popup menu choose Factor Settings > Set to Data in Row...
The profiler setting should shift to that row. Choose that again with a new row number to switch to the next row and so on.
Dan Obermiller
