Yes, it is possible with small changes directly to that script. I added debug column which you can remove to show that it matches correct rows
dt = New Table("RawData",
Add Rows(27),
Compress File When Saved(1),
New Column("serial_number",
Character,
"Nominal",
Set Values(
{"A", "A", "A", "A", "A", "A", "A", "B", "B", "B", "B", "B", "B", "C", "C", "C", "C", "C", "C", "C", "D", "D", "D", "D", "D", "D", "D"}
New Column("rel_event",
Character,
"Nominal",
Set Values(
{"REL_T0", "DROP1", "DROP2", "DROP3", "DROP4", "DROP5", "DROP6", "REL_T0", "DROP1", "DROP2", "DROP3", "DROP4", "DROP5", "REL_T0", "DROP1",
"DROP2", "DROP3", "DROP4", "DROP5", "DROP6", "DROP1", "DROP2", "DROP3", "REL_T0", "DROP4", "DROP5", "DROP6"}
New Column("metric1",
Numeric,
"Continuous",
Format("Best", 10),
Set Values([1, 2, 3, 5, 7, 10, 13, 2, 4, 5, 6, 8, 11, 1, 2, 4, 5, 5, 9, 12, 1, 2, 4, 5, 5, 9, 12])
New Column("metric2",
Numeric,
"Continuous",
Format("Best", 10),
Set Values([2, 3, 4, 7, 9, 14, 18, 2, 3, 4, 7, 9, 14, 2, 5, 7, 8, 9, 11, 13, 2, 5, 7, 8, 9, 11, 13])
debugcol = dt << New Column("REL_T0_ROW", Numeric, Continuous);
delta1col = dt << New Column("delta1", Numeric, Continuous);
delta2col = dt << New Column("delta2", Numeric, Continuous);
For Each Row(dt,
// find REL_T0 row for current serial_number
start_row = Col Min(If(:rel_event == "REL_T0", Row(), .), :serial_number);
debugcol[Row()] = start_row;
delta1col[Row()] = :metric1 - :metric1[start_row];
delta2col[Row()] = :metric2 - :metric2[start_row];
