Opening an Application Reference file from JMP
I have an application on my Windows PC, which is started up by running a file who's file property says it's Type of File is: Application Reference ( appref-ms ).
Attempts to reference from Run Program() come back with a message indicating that no file was found.
Does anyone have a solution?
Re: Opening an Application Reference file from JMP
I'm guessing the answer is here
https://stackoverflow.com/questions/10766334/how-to-find-the-target-exe-file-of-appref-ms
but I've not (knowingly) been down that path.
@Anonymous
@Anonymous
Craige,
Thanks for the pointer...….it is works great
