Level XIII
Oops - I lost my data ...
Remember, you must not ....
  1. create a virtual link with a wrong table reference (fixed <= v18.2.2)
  2. create a summary table with a compact column  (fixed <= v18.2.2)
It makes your data table non-accessible!
[More Topic Containers like this]
12 REPLIES 12
HaltsMaulwurf
Re: How to make a data table non-accessible?
Thanks hogi,
I could rescue a few of my datasets with your solution! Highly appreciated
Why would you want to make your data non-accessible in such a way that it is basically corrupted?
Level XIII
Re: Oops - I lost my data ...
option 2)  create a summary table
- with a link to the main table (default)
- with a compact column
dt = New Table( "input",
	Add Rows( 3 ),
	New Column( "ID",
		Character,
		"Nominal",
		Set Values( {"A_1", "A_2", "A_3"} ),
		Compact() // <- disable to remove the bug
dt sum = dt << Summary(	Group( :ID ),
//Link to original data table( 0 ) // <- uncomment to disable the bug
fn = "$temp\bug" || Char(random integer(10000))||".jmp";
dtsum  << Save( fn );
Close( dt sum, NoSave );
Try(open(fn), Caption("sorry, the file is damaged"));
When you try to open the file manually, JMP will display an error message:
same issue with linked subset tables?
fixed in JMP18.2.2?
