Gadsdon
JMP16: Process Performance plot, removal of 1.33 curve and triangles
In versions before JMP16, I was previously a JMP14 user, we could remove the 1.33 curve and now I also see triangles to idnetify process position.  How can I remove the Cpk1.33 curve and make everything circles.  I find these elements a bit distracting
ih
Super User (Alumni) ih
Re: JMP16: Process Performance plot, removal of 1.33 curve and triangles
For the markers, if you right click in the graph and select 'Customize', changing the capability markers to anything other than the top left option (an open circle or a larger filled circle) should get rid of the triangle.  I'm not sure about the 1.33 curve; you can right click on it in the legend to change the color which might help..
Hi, you can remove the curve if you right click on the CpK1.33 in the legend and put transparency to 0. Hope this helps.
