Level XII
Oops - I lost my data ...
8 REPLIES 8
Level XII
Re: Oops - I lost my data ...
option 1):
add a Link with a non-resolved reference:
Names Default to Here(1);
testMode= 1;
dt =  Open( "$SAMPLE_DATA/Big Class.jmp" );
dt << new column("Conan the Destroyer",Set Property("Link Reference", {Reference Table(link_path), Options("Use Linked Column Name", "Auto Open")}));
dt << save("$TEMP/test.jmp");
close(dt, noSave);
open("$TEMP/test.jmp");
Re: How to make a data table non-accessible?
In what sense non-accessible?
Level XII
In the sense of "dead".
Level XII
The good thing:
JMP stores the Table reference in plain text ...
By deleting the ", Auto Open" one can revive the file:
JMP will show a warning message:
and skip the details of the erroneous column.
What is the purpose of this thread?
Level XII
mainly: Help people save their work.
Besides that:
a) Documentation: Things you should NOT (!!) do with your data table.
b) Motivation:
@ colleagues - please invest 30 minutes to understand the beauty of Eval/Eval Expr/Expr
(the basics: # 62, some examples: #66)  ---  it will save you from lost data like this one.
c) preventive action:
-> I will add a check + warning functionality to the hogi_0-1733168619557.png button ...
if a variable is defined in the script - and the variable shows up in a message (<<  ...) ... show a WARNING !
Level XII
@hogi wrote:
a check + warning functionality  ...
myscript = Parse( Current Window()[Script Box( 1 )] << get text );
variables = {};
// find the assignments and collect the JSL variables
assigns = Extract Expr All Matches(
	Name Expr( myscript ),
	Expr( Assign( Wild List() ) )
For Each( {item}, assigns, Insert Into( variables, Arg( item, 1 ) ) );
// collect the messages
messages = Extract Expr All Matches(
	Expr(
		Send( Wild(), Wild List() )
For Each( {message}, messages,
// bother an experienced user just when he forgot to use Expr:
	// assuming there is a surrounding Eval (Eval Expr()),  remove all the Expr() - including the content [dirty]
		Arg( Name Expr( message ), 2 ),
		Expr( Expr( Wild List() ) )
	);  // returns: cleanedExpr, without the Expr()s
	//search for variables
	For Each( {variable, idx}, variables,
		If(
			Not(
				Is Empty(
					Eval(
						Eval Expr(
							Extract Expr(
								Expr(
									Name Expr( cleanedExpr )
								Expr( Name Expr( variable ) )
			Caption(
				Char( variables[idx] ) || " found in a message to " ||
				Char( Arg( Name Expr( message ), 1 ) ) ||
				".\!n Please correct it with Eval(Eval Expr( ... Expr()))"
			Stop();
//Extract Expr All Matches?
// it works like Extract Expr, but doesn't stop after the first match.
// saves the "cleaned" expression as cleanedExpr
Why would you want to make your data non-accessible in such a way that it is basically corrupted?
