Level XIII
Oops - I lost my data ...
Remember, you must not ....
  1. create a virtual link with a wrong table reference (fixed <= v18.2.2)
  2. create a summary table with a compact column  (fixed <= v18.2.2)
It makes your data table non-accessible!
[More Topic Containers like this]
12 REPLIES 12
Level XIII
Re: Oops - I lost my data ...
option 1):
add a Link with a non-resolved reference:
Names Default to Here(1);
dt =  Open( "$SAMPLE_DATA/Big Class.jmp" );
dt << new column("Conan the Destroyer",Set Property("Link Reference", {Reference Table(link_path), Options("Use Linked Column Name", "Auto Open")}));
dt << save("$TEMP/test.jmp");
close(dt, noSave);
open("$TEMP/test.jmp");
fixed in JMP18.2.2?
I believe understand the problem after speaking with another colleague.
The issue here is the JMP user interface will not allow one to save a table, with Auto Open selected, while an invalid Link Reference path exists. The JMP UI will save the table but will set the Auto Open option. So the table can be opened or recovered.
In JSL however, it is permitted. The table is saved with Auto Open and an invalid Link Reference. This prevents JMP from opening the table. The JMP UI has some sort of safety check in place that is not built into JSL.
I've reported this issue so it can be addressed in a future release.
Best!
Dahlia Watkins
Level XIII
#1:
Hi @Dahlia_Watkins , thank you for digging deeper and triggering a bugfix for a future release : )
[TS - 00177463]
Re: How to make a data table non-accessible?
In what sense non-accessible?
Level XIII
In the sense of "dead".
Level XIII
The good thing:
JMP stores the Table reference in plain text ...
By deleting the ", Auto Open" one can revive the file:
JMP will show a warning message:
and skip the details of the erroneous column.
What is the purpose of this thread?
Level XIII
mainly: Help people save their work.
Besides that:
a) Documentation: Things you should NOT (!!) do with your data table.
b) Motivation:
@ colleagues - please invest 30 minutes to understand the beauty of Eval/Eval Expr/Expr
(the basics: # 62, some examples: #66)  ---  it will save you from lost data like this one.
c) preventive action:
-> I will add a check + warning functionality to the hogi_0-1733168619557.png button ...
if a variable is defined in the script - and the variable shows up in a message (<<  ...) ... show a WARNING !
Level XIII
@hogi wrote:
a check + warning functionality  ...
(view in My Videos)
