fishguy
Obtaining 95% CI from predicted P (logistic)
I'm doing logistic regression in JMP 16. I would like to obtain the 95% CI around predicted P for some independent variables using the P as a measure of strength of association. I know the math to calculate the 95% CI from linear predictors but I need help pulling out the necessary information once I run the model. I can obtain the linear predictor by saving to a new column, but I also need the standard error of the linear predictor. How do I obtain that? I have done this in R but I would prefer to learn in JMP.
pauldeen
Re: Obtaining 95% CI from predicted P (logistic)
do the logistics modeling use Fit model you can turn on CI in the hotspot menu:
This will give you CI on the parameter estimates table.
From the same hotspot you can also save the probability formula's.
pauldeen
fishguy
Thanks for reply. Turning on CI gives me the CI around the chiSq tests for each term, but what I'm after is obtaining a CI around the expected value (probability of "1" or "yes"). To calculate the CI, one needs the linear predictor as well as the SE.  I can get the linear predictor and the expected value from the save drop down choices but I can't find where to obtain the SE of the linear predictor.
95% confidence interval formula:
Lp-1.96* se(Lp), Lp+1.96*se(Lp)
Lp - linear predictor
fishguy
...and to finish the thought, this is the formula to get CI around probabilities (expected values) once you have the linear predictor interval:
Lp interval [a, b]
Probability interval:
[exp(a)/1+exp(a), exp(b)/1+exp(b)]
[lower, upper]
pauldeen
Did you notice the Std Error column in the parameter estimates table?
fishguy
Thanks much! My bad. I thought it was for something else.
pauldeen
Cool! If you are satisfied, please mark the topic as solved so that other people know it is done
