RandomFed
Rosner's Outlier Test
Good afternoon,
is it possible to perform the Rosner's Outlier Test in JMP?
Thanks
Re: Rosner's Outlier Test
it is possible to perform this test but there is no built-in capability. (JMP provides many exploratory tools for identifying outliers but none of the popular outlier tests such as those by Grubbs, Dixon, or Rosner.) You can write a script to implement it and extend JMP. You can also use the R package with JMP and return the test results.
RandomFed
Thanks!
