キャンセル
次の結果を表示
表示  限定  | 次の代わりに検索
もしかして:
言語を選択 翻訳バーを非表示
GZ78
Numeric values in wrong order on axis
I am trying to plot some data in graph builder, but the numeric values (x axis below) plot in order of the number while ignoring the decimal place.  I am plotting overlays that use the same 116 numeric categories on the x-axis, so dragging these values manually is not efficient.  The values are in the correct order within the data table.  What settings can I use to maintain either the order assigned in the data table or force them to read from smallest to largerst without ignoring the decimal place?
2 件の受理された解決策
受理された解決策
Re: Numeric values in wrong order on axis
If you make your x axis variable continuous, I believe that would correct the problem.
Dan Obermiller
元の投稿で解決策を見る
Perhaps you have a value ordering property turned on? Any chance you could share some of the data?
Dan Obermiller
元の投稿で解決策を見る
4件の返信4
Dan Obermiller
GZ78
I had already assigned it as continuous. I reattempted that and I get the same issue. I have also tried fixing the decimal places to three. (for example values with 0.001, 0.010 and 0.100). Neither of these seemed to work.
Dan Obermiller
GZ78
We were both headed in that direction.  There was a value ordering setting already applied in the data.  I removed this and reset all the column settings.  I am now getting the plot I need.  Thanks for the help, Dan!
おすすめの記事
