Learn how to build custom Python data connectors and further customize JMP’s Data Connector Framework with the Python Data Connector Demo, available now in the JMP Marketplace!
See how to create experiments to support product design and ID useful product features. Register for June 12 webinar, 2pm US Eastern Time.
I would like to reproduce the type of plot shown in the attached figure. The graph displays multiple datasets overlaid on a Normal Probability (Probit) scale on the Y‑axis, with each group shown using different marker colors and shapes.
Could you please advise which JMP platform(s) and workflow are best suited to generate such a graph?
More specifically, I would like to know:
Which JMP platform to use (e.g., Graph Builder, Distribution, Fit Y by X, or Probability Plot)
How to set the Y‑axis to Normal Probit (σ units)
How to overlay multiple groups on the same probability plot
How to customize markers and colors for each group
How to add a legend similar to the one in the example
Whether the underlying data table needs to be in long format (Value, Group) or wide format
Any example, instructions, or JSL script would be extremely helpful.
I will use Big Class (JMP Sample Data folder) to illustrate. I assume that all the data is stacked in one column for the Y role. The corresponding group assignments exist in another column.
Select Analyze > Distribution
Select the height data column and click Y
Select the grouping column sex and click By
Click OK
The distribution platform will compute the quantiles and save them for you.
Press and hold the CTRL key with Windows or the Command key with Mac
Click the red triangle for height and select Normal Quantile Plot
Click the red triangle for height and select Save > Normal Quantiles.
Click OK
- select your variable and in the right click menu pick Distributional: Cumulative Probability - activate Scoping : Overlay and pick the Overlay column - use Normal Probability in the axis settings
