Gabriel
Non-parametric test
Good day,
I would like assistance with the ANOVA equivalent for a non-parametric test.
I understand that to do this there are several options in JMP, one which is the The Kruskal-Wallis test, however, I am stuck on how to use this for:
1. Two/three way type of ANOVA in the case of a parametric test.
2. When I try using the Fit Y by X option using Steel-Dwass there are no option for connecting letters. (I see a lot of people have requested for this option on JMP, is there by any way a solution yet? I would really appreciate one).
Thanks for assistance.
Gabriel Mulero
Byron_JMP
Re: Non-parametric test
Sounds like some good feature requests for the JMP Wish List (5th tab in the blue bar at the top of the screen)
