JP27
Newbie - What am I doing (forecasting hospital admission/Time Series analysis)
Newbie here with little experience in coding (medical background).
I was given this database which contains all hospital admissions during a 1 year period.
Each row represents an individual admission, and columns contain variables like date of admission (YY/MM/DD hh:mm) or source of admission (home, transfer from other hospital, etc).
This is a very simplified version of how my table looks like. Actual table contains thousands of admissions. Admission date is in ascending order.
I was instructed to develop a forecasting model to see how many admissions we can expect in the following month/year based on this data. I did a bit of research and consider that a Time Series analysis could work for our purpose. It should be something simple: to forecast future daily admissions based on current daily admissions.
The only way I have been able to get some output was by using by admission date variable in the Y axis, and I am getting something like this:
Instead, I am hoping to get something like this:
I know I am probably missing some super basic concepts. I read and did the exercises in the JMP book but still I can't solve this. Thank you in advance!
Re: Newbie - What am I doing (forecasting hospital admission/Time Series analysis)
Here are my thoughts:
1. History does not predict the future.
2. You want a model to predict the future, you need to study the admissions process to get an understanding of causal factors that affect admissions.  You might also question the admissions data.  How accurate is it?  Are the times/dates correct?  Are there potential opportunities to distort the data (for legal or financial reasons)?
3. I would use control charts to first answer the question "Is the admissions process consistent and stable?"  If so, you may extend those control limits as a "prediction" of future admissions given the future conditions are appropriately represented in the data set you currently have (for example, what if we are hit with another pandemic or natural disaster and this  is not represented in the current 1 year data?).  If not, you should seek to understand why.
FN
FN
I would look into the Time Series Forecasting platform.
https://www.jmp.com/en_gb/learning-library/topics/time-series/time-series-forecasting.html
With a good read of this great and free book:
https://otexts.com/fpp2/
peng_liu
I cannot see the y-axis label in your targeted result due to resolution. But I believe that is not in your data. So a hint is can you get the data into the shape that is required for your targeted plot?
