AmberA
New to JSL - Clear selection, invisible usage
I am very new to JSL, couple of questions:
1). I am setting up a script to plot bar graphs and send to ppt. After the script runs, the final bars in the graph window are selected (see diagonal shading on the bars). I want to unselect these bars  before sliding them to the ppt. (see attachment). I need to find the command to unmark the selection
2). I want to close the data table after making all the graphs and saving them to ppt. IF I use the command close (dt); where dt is my data table - this closes the data table and no graphs are produced.
3). I need to apply multiple data filters for various graphs in the same script. Is there a sample script that shows how to do it? I have tried using 'local' filter but that confines the filter and does not apply it to my graph. I have tried using dt<< clear row states; before applying the new filter but that is not working either.
4). Is there a sample script showing how to use 'invisble' for graph windows?
uday_guntupalli
Level VIII
Re: New to JSL - Clear selection, invisible usage
 // Open Sample Data
// Select rows
dt << select Where(:age ==12);
// Clear Selection
dt << clear select
 For question # 1 - see above example
Graph1 << Show Window(0);
Fow question #4 - above code should hide the window or make it "invisible" - where Graph1 represents the graph window
For question # 2 ,
- Save the graphs to the ppt first and close the ppt and then close the data table - this should fix it .
For question  #3 ,
 - Can you provide sample code of what you are trying to do - this should be easy .
Best
Uday
Best
Uday
pmroz
I can answer a few of your questions:
1. You need to clear any selections made in your table.  You can do this via:
dt << clear select;
where dt points to your data table
3. After creating your graph, add a filter by clicking on the little red triangle > Script > Local Data Filter.  Then add one or more variables as a filter column.  Now click the little red triangle next to Graph Builder and select Copy Script.  Here's an example:
dt = open("$sample_data\Big Class.jmp");
Graph Builder(
	Size( 526, 451 ),
	Variables( X( :weight ), Y( :height ) ),
	Elements( Points( X, Y, Legend( 12 ) ), Smoother( X, Y, Legend( 13 ) ) ),
	Local Data Filter( Add Filter( columns( :sex ) ) )
uday_guntupalli
Level VIII
 // Open Sample Data
// Select rows
// Clear Selection
dt << clear select
For question # 2 ,
For question  #3 ,
Best
Uday
Best
Uday
pmroz
dt << clear select;
Graph Builder(
	Size( 526, 451 ),
