venkateshc78
New Sequence column creation based on another ID columns
I've an existing column which has the Customer ID which occurs multiple times in the whole data table on a different date/time. I want to create a sequence such as 1,2,3 for each of the Unique Customer ID based on the date/time variable. How to acheive the same in JMP ?
Sample Data snippet (Customer ID | Date)
ABC | 1-JUN-2019
XYZ | 1-JUN-2019
ABC | 3-JUN-2019
ABC | 4-JUN-2019
XYZ | 7-JUN-2019
I want to create a result like below ((Customer ID | Date | Sequence for Customre ID/Date combination)
ABC | 1-JUN-2019 | 1
XYZ | 1-JUN-2019 | 1
ABC | 3-JUN-2019 | 2
ABC | 4-JUN-2019 | 3
XYZ | 7-JUN-2019 | 2
Please advise
Re: New Sequence column creation based on another ID columns
Here is a formula that will work
theRow = Row();
theCustomer = :Customer ID;
seq = N Rows( dt << get rows where( :Customer ID == theCustomer & Row() < theRow ) ) + 1;
ron_horne
