New to JMP? Let the Data Analysis Director guide you through selecting an analysis task, an analysis goal, and a data type. Available now in the JMP Marketplace!
I've recently discovered the awesomeness of Window>New Data View. This allows you to have two screens of a datatable. One datatable, but two instances making it easier to edit in large tables. This would be a great feature if I could also do this with my JSL scripts.
I agree, but I would be equally happy with a split window feature in the script editor. Line bookmarks would be great too (ctrl-F2 to toggle and F2 / shift-F2 to move to next / previous). I thought these were going to be implemented for JMP12 but so far haven't seen them. I mostly use JMP11 so I may have missed it.
My mistake... I forgot split was accessible from the right click menu, in JMP 11 as well (which is what I mostly use) but I don't remember about earlier versions.
Thanks for the reply, I see how my OP was a little misleading and this too could be a correct answer. Craig's answer was more of what I was going for. Although, I'd still prefer a second window versus a split screen.
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '16989' && "ForumTopicPage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if(value == '16989') {
}else{
sub_L = newSub.innerHTML;
else{
} else {
try{
catch(e){
if (value == '16989') {
if(subTkbElement){
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
