cis_pete
Bug in graph builder with grid lines and right side axes?
I think I found a bug (in JMP 12.1). Please try this script:
gb = dt << Graph Builder(
    Size( 570, 667 ),
    Show Control Panel( 0 ),
    Variables(
        X( :age ),
        Y( :height ),
        Y( :weight, Position( 1 ), Side( "Right" ) ),
        Y( :age ),
        Y( :name )
    Elements(
        Position( 1, 1 ),
        Points( X, Y( 1 ), Legend( 5 ) ),
        Smoother( X, Y( 1 ), Legend( 6 ) ),
        Points( X, Y( 2 ), Legend( 7 ) ),
        Smoother( X, Y( 2 ), Legend( 8 ) )
    Elements( Position( 1, 2 ), Points( X, Y, Legend( 10 ) ) ),
    Elements( Position( 1, 3 ), Points( X, Y, Legend( 11 ) ) ),
        Dispatch(
            "height",
            ScaleBox,
            {Label Row( {Show Major Grid( 0 ), Show Minor Grid( 0 )} )}
        Dispatch(
            "weight",
            ScaleBox,
            {Label Row( {Show Major Grid( 1 ), Show Minor Grid( 1 )} )}
        Dispatch( {}, "age", ScaleBox( 2 ), {Label Row( Show Major Grid( 0 ) )} ),
        Dispatch( {}, "name", ScaleBox, {Label Row( Show Major Grid( 0 ) )} )
If the checkboxes "Major Grid Lines" and "Minor Grid Lines" are NOT checked in Preferences (Styles -> Tick Marks and Grid Lines) the graph looks ok. But if they are checked you will get the grid lines from "weight" for the parameters "age" and "name". These grid lines disappear when you move "weight" to the left. Very strange.
Can anybody explain what is happening here or is it just a bug?
cis_pete
Re: Bug in graph builder with grid lines and right side axes?
PS: You even get the grid lines for "age" and "name" if the grid lines for "weight" are turned off:
    Dispatch(
        "weight",
        ScaleBox,
