Wantj43
Neg number
Graph builder generates a negative data point in a scatterplot - however the data point is positive in the database.
I have re-entered the data but still represented as a negative data point.
Any help appreciated.
Using jmp14.
Thank you
Joe
Wantj43
Re: Neg number
I would like to thank everyone for the help.
The source of the problem was a data entry error on my part.
Joe
Re: Neg number
Could you supply an image of the graph, and a sample of the data?
Wantj43
Re: Neg number
Attached is the scatterplot.
A review of the both the original Access and the jmp file display the number as "positive".
Thank you for the assistance.
Joe
Re: Neg number
I suggest that you submit this to the JMP support group.  You may be more comfortable providing them your data.  I have never run across this issue, and having the data is really necessary to investigate the issue.
Jeff_Perkinson
Re: Neg number
I'll agree with @txnelson. It's going to be hard to diagnose without seeing the data table directly. I've never seen a case where JMP is plotting the data incorrectly. If you can share just that column of data or even just those two points as a JMP data table that will help.
What does the Distribution report for that column look like? Can you share that?
-Jeff
Wantj43
Re: Neg number
Joe
